- To: <>
- Subject: suggestion/bugfix and a question.
- Date: Fri, 14 Sep 2007 12:55:03 +0200
- Organization: pha
Team. I’ve been getting some failures in function
precondition_fail ( assertions.cpp CGAL 3.3) The following change seems to fix it. If I knew how to make a patch I’d have done
that instead!! void precondition_fail( const char* expr, const char* file, int line, const char* msg ) { (*_error_handler)("precondition",
expr, file, line, msg); switch (_error_behaviour) { case ABORT:
CGAL_CLIB_STD::abort(); case EXIT:
CGAL_CLIB_STD::exit(1); //
EXIT_FAILURE case EXIT_WITH_SUCCESS: CGAL_CLIB_STD::exit(0);
// EXIT_SUCCESS case THROW_EXCEPTION: if(msg) throw Precondition_exception("CGAL", expr,
file, line, msg); else throw Precondition_exception("CGAL", expr,
file, line, "with no
Message"); case CONTINUE: ; } } And the question… Is it OK to mix kernel types
in a single application? The reason I ask is that I’m using the Exact_predicates_inexact_constructions_kernel
because the exact kernel is too slow. Not surprisingly I get quite a lot of precondition
exceptions, for instance when trying to intersect nearly-contiguous polygons. It would be nice to catch these exceptions and then recover
by trying the same operation with the exact kernel. Is this workable? Peter (mob) +33 681307652 Home +33 2 97 82 19 30
Peter Heppel Associates
8 rue du Faubourg Poissonnière
75010 Paris –
- suggestion/bugfix and a question., peter heppel, 09/14/2007
