- To:
- Subject: Re: [cgal-discuss] *stream.h backward compatability
- Date: Fri, 14 Sep 2007 15:34:13 +0200
Hello Stefan,
They have been removed from the documentation in CGAL 3.2
They were abandonned as they were wrappers of leda functionality.
As only few CGAL project partners have a license for leda, and
as Qt is the favored windows toolkit and also can generate
postscript, these packages will not be resurrected. At least
we haven't allocated ressources for this.
Best regards,
andreas
wrote:
Apparently, IO/Window_stream.h and IO/Postscript_stream.h have been silently
(= no announcement on the release history) removed starting with CGAL-3.3.
What is the intended workaround?
Furthermore, IO/Min_ellipse_2_Window_stream.h tries #include <CGAL/IO/Conic_2_Window_stream.h> but this file does not exist anymore.
best regards
Stefan
- *stream.h backward compatability, stschirr, 09/14/2007
- Re: [cgal-discuss] *stream.h backward compatability, Andreas Fabri, 09/14/2007
