- To:
- Subject: Re: [cgal-discuss] Delaunay3D and infinite cells bug??
- Date: Thu, 20 Sep 2007 08:46:58 +0200
Hi Wesley,
I can;t reproduce what you write. Can you post a complete minimal
program.
Are you looking for the vertices on the convex hull?
Just take the cells incident to the infinite vertex,
and collect the vertices on the faces opposite to the
infinite vertex.
andreas
Wesley Smith wrote:
I've found a case in the delaunay_3d class where a vertex on the crust
of a triangulation doesn't have any incident infinite cells. Should
this ever happen or is this a bug? Here's are the points I'm
inserting:
for(int i=-1; i <= 1; i++) {
for(int j=-1; j <= 1; j++) {
for(int k=-1; k <= 1; k++) {
L.push_front(Point(i, j, k));
dg = new DG(L.begin(), L.end());
The test:
for(Finite_vertices_iterator fv = dg->finite_vertices_begin();
fv != dg->finite_vertices_end(); fv++) {
Delaunay_vertex_handle v(fv);
vector<Cell_handle> cells;
dg->incident_cells(v, std::back_inserter(cells));
int c = 0;
int size = cells.size();
for(c = 0; c < size; c++) {
if(dg->is_infinite(cells[c])) {
break;
if(c == size) {
Point p = v->point();
printf("NOT ON CRUST %f %f %f\n", p.x(), p.y(),
p.z());
continue;
Of the points inserted, this test determines that (0, 0, 0) and (1, 0,
0) are not on the crust (i.e. of no incident infinite cells). Clearly
(0, 0, 0) is valid, but (1, 0, 0) is not. I ran some further tests,
revering the insertion order of the points and that case, (0, 0, 0)
and (-1, 0, 0) are determined to not have any incident infinite cells.
It was my understanding that all vertices on the crust of the
triangulation would have at least one infinite cell. Is my test just
using some artifact of the triangulation algorithm or should I be able
to count on it? Essentially, I'm looking for a fast method to test
for a vertex being on the crust (not an arbitrary point but a vertex
inserted into the triangulation). I'm a bit surprised there isn't a
method for this actually, but any help in figuring this out will be
greatly appreciated.
thanks,
wes
- Delaunay3D and infinite cells bug??, Wesley Smith, 09/20/2007
- Re: [cgal-discuss] Delaunay3D and infinite cells bug??, Andreas Fabri, 09/20/2007
- Re: [cgal-discuss] Delaunay3D and infinite cells bug??, Wesley Smith, 09/20/2007
- Re: [cgal-discuss] Delaunay3D and infinite cells bug??, Monique . Teillaud, 09/20/2007
