- To:
- Subject: Install script doesn't detect Boost
- Date: Sun, 23 Sep 2007 01:11:59 -0400
- Priority: normal
I'm attempting to compile CGAL, but it's not detecting Boost for some reason.
http://www.cgal.org/platforms.html indicates that Boost doesn't have to be
compiled; good thing, too, because I don't have the extra gigabytes necessary
for that monster. It also says I need to set the BOOSTROOT environment
variable, which I've done.
I'm running OSX 10.4.10, and trying to compile CGAL 3.3.1, incidentally.
The "env" command in bash returns:
TERM_PROGRAM=Apple_Terminal
TERM=xterm-color
SHELL=/bin/bash
TERM_PROGRAM_VERSION=133
OLDPWD=/Users/lfrench
BOOSTROOT=/Developer/Headers/boost_1_34_1/
USER=lfrench
__CF_USER_TEXT_ENCODING=0x1F5:0:0
PATH=/bin:/sbin:/usr/bin:/usr/sbin
PWD=/Developer/Headers/CGAL-3.3.1
SHLVL=1
HOME=/Users/lfrench
SECURITYSESSIONID=<dunno if this is sensitive, edited anyway>
_=/usr/bin/env
My install.log is attached. Any help would be appreciated. While I'm willing
to implement my own Delaunay triangulation algorithm, I was really hoping not
to have to; and if I can't make CGAL work, I'll just have to try another.
install.log
Description: Binary data
- Install script doesn't detect Boost, Lindley M French, 09/23/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Laurent Rineau, 09/23/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Lindley M French, 09/23/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Lindley M French, 09/24/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Laurent Rineau, 09/24/2007
