cgal-discuss - Re: [cgal-discuss] Grey_level_image triangulation to STL file
  • To:
  • Subject: Re: [cgal-discuss] Grey_level_image triangulation to STL file
  • Date: Sun, 23 Sep 2007 18:53:22 +0200
  • Organization: Inria, Sophia Antipolis, FRANCE
On Sunday 23 September 2007 17:11:39 Tobias Prousa wrote:
> thanks to your reply I achieved compiling some code which gives me a STL
> file with the correct surface. The only problem is that the face-normals
> are still pointing to random directions, some point out of object, others
> point into it.
The output of the meshing algorithm is not always an orientable manifold
surface. However, it has been proved[1] that, if the output is not manifold,
the size criteria are, at some place on the surface, bigger than the local
feature size of the surface.
For that reason, the meshing algorithm cannot output oriented facets, in the
general case. A post-process treatment needs to check is the output surface
is manifold, and orientable, and then orient all facets with the same
orientation.
[1] Jean-Daniel Boissonnat and Steve Oudot. Provably good sampling and
meshing
of surfaces. Graphical Models, 67:405-451, 2005.
> I used output_surface_facets_to_off as inspiration, but the part when the
> macro CGAL_C2T3_USE_POLYHEDRON is disabled. The other portion of the
> function didn't work for me at all.
Only the portion with CGAL_C2T3_USE_POLYHEDRON enabled makes a sorting of the
output facets, so that all normals have the same orientation. Maybe your
output surface is not a polyhedron.
I have another piece of code that orients an OFF file (actually, it also
merges identical points, if any, in a single vertex). See the attachment. I
give you that piece of code under the QPL license (see the file LICENSE.QPL
in the CGAL directory). It use, under Unix, when the file is compiled, isĀ :
./identify_identical_points_in_OFF_files < buggy_file.off > fixed_file.off
That piece of software does its best to orient the surface: even if the
surface is non manifold, it tries to orient facets as much as possible.
> Is there any (simple) way to determine if the normal vector calculated as
> cross product of the vectors p1-p0 and p2-p0 (p0,p1,p2 are the points of a
> surface-facet) points to the inside or the outside of the surface-meshed
> body?
> Or is there some cgal built in function to get an oriented normal
> vector for each facet.
CGAL cannot do magic. As I have explained above, the meshing algorithm
cannot,
in the general case, orient the surface. That is why it does not try to
orient it at all. In future versions of CGAL, i will probably publish and
document a function that tries to orient a surface, and does its best, like
the piece of code attached.
> I want to use this for creating 3d meshes (using netgen) of easily
> modifyable bodies. The meshes then will be used for studying flow behaviour
> using OpenFOAM, an open source CFD software suite.
Interresting to know. Where do you work?
Let me know if you manage to use the CGAL surface mesh generator, for that
use.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
// Copyright (c) 2007  INRIA Sophia-Antipolis (France).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL: $
// $Id: $
// Author(s)     : Laurent Rineau
#include <iostream>
#include <string>
#include <vector>
#include <map>
#include <stack>
#include <boost/tuple/tuple.hpp>
#include <boost/tuple/tuple_comparison.hpp>
#include <boost/format.hpp>
using std::cout;
using std::cin;
using std::endl;
int main()
  std::string header;
  cin >> header;
  if(header != "OFF")
    std::cerr << "header is \"" << header << "\"\nshould be \"OFF\".\n";
    return 1;
  cout << header << endl;
  unsigned int n_vertices;
  unsigned int n_facets;
  std::string dummy;
  cin >> n_vertices;
  cin >> n_facets;
  getline(cin, dummy);
  // Vector that maps from old vertex index to new vertex index,
  // as some (old) vertices may have identical point coordinates.
  std::vector<int> new_index(n_vertices);
  typedef boost::tuple<double, double, double> Point;
  // Vector that stores the points coordinates (in a Point).
  std::vector<Point> points(n_vertices);
  // Map that retains the mapping from the point coordinates (in a Point)
  // to the nex index.
  typedef std::map<Point, int> Renumber;
  Renumber renumber;
  unsigned int index = 0;
  for(unsigned int i = 0; i < n_vertices; ++i)
    cin >> boost::get<0>(points[index])
	>> boost::get<1>(points[index]) >> boost::get<2>(points[index]);
    Renumber::const_iterator it = renumber.find(points[index]);
    if( it == renumber.end() )
      renumber[points[index]] = index;
      new_index[i] = index;
      ++index;
    else
      new_index[i] = it->second;
  cout << index << " " << n_facets << dummy << endl;
  for(unsigned int i = 0; i < index; ++i)
    cout << boost::get<0>(points[i]) << " "
	 << boost::get<1>(points[i]) << " "
	 << boost::get<2>(points[i]) << "\n";
  // Vector that stores each facet.
  typedef std::vector<boost::tuple<int, int, int> > Facets;
  Facets facets;
  // For each (oriented) edge, that map stores a vector of adjacent facets,
  // with a boolean that tells if the edge is in the opposite orientation,
  // in the facet.
  // Edges are stores in the direction from the smallest index to the
  // greatest.
  typedef std::pair<int, int> Edge;
  typedef std::map<Edge, std::vector<std::pair<int, bool> > > Edges_map;
  Edges_map edges;
  // "nested function" opposite, that returns the edge, in the opposite
  // direction.
  struct {
    Edge operator()(Edge e) const {
      return std::make_pair(e.second, e.first);
  } opposite;
  for(unsigned int i_facet = 0; i_facet < n_facets; ++i_facet)
    // Read a facet, then reindex its vertices.
    int i, j, k;
    cin >> dummy >> i >> j >> k;
    if( dummy != "3" )
      std::cerr << "In facet #" << i_facet << ", expected \"3\", found \""
		<< dummy << "\"!\n";
      return 1;
    i = new_index[i];
    j = new_index[j];
    k = new_index[k];
    facets.push_back(boost::make_tuple(i, j, k));
    // Create the three edges of the facet.
    Edge e[3];
    e[0] = std::make_pair(i, j);
    e[1] = std::make_pair(j, k);
    e[2] = std::make_pair(k, i);
    for(int i_edge = 0; i_edge < 3; ++i_edge)
      if( e[i_edge].first < e[i_edge].second )
	edges[e[i_edge]].push_back(std::make_pair(i_facet, false));
      else
	edges[opposite(e[i_edge])].push_back(std::make_pair(i_facet, true));
  // Map that stores all already passed facet, and retains the orientation
  // of the facet. "true" means that the facet needs to be reoriented.
  std::map<int, bool> oriented_set;
  // Stack of facets indices to be handled.
  std::stack<int> stack;
  int seed_facet_candidate = 0;
  while (oriented_set.size() != n_facets) {
    // find a facet index that is not yet in 'oriented_set'.
    while( oriented_set.find(seed_facet_candidate) != oriented_set.end() )
      ++seed_facet_candidate;
    std::cerr << "Need seed facet: " << seed_facet_candidate << "\n";
    // push it in oriented set
    oriented_set[seed_facet_candidate] = false;
    stack.push(seed_facet_candidate);
    while(! stack.empty() ) {
      const int f = stack.top();
      stack.pop();
      const int i = boost::get<0>(facets[f]);
      const int j = boost::get<1>(facets[f]);
      const int k = boost::get<2>(facets[f]);
      Edge e[3];
      for(int ih = 0 ; ih < 3 ; ++ih)
	bool f_orient = false;
	if(e[ih].first > e[ih].second) {
	  f_orient = true;
	  e[ih] = opposite(e[ih]);
	Edges_map::iterator edge_it = edges.find(e[ih]);
	if(edge_it->second.size() == 2) { // regular edge
	  int fn = edge_it->second[0].first;
	  bool fn_orient = edge_it->second[0].second;
	  if(fn == f)
	    fn = edge_it->second[1].first;
	    fn_orient = edge_it->second[1].second;
	  if (oriented_set.find(fn) == oriented_set.end())
	    if(f_orient == fn_orient)
	      oriented_set[fn] = ! oriented_set[f];
	    else
	      oriented_set[fn] = oriented_set[f];
	    stack.push(fn);
	} // end "if the edge is regular"
	else {
	  std::cerr << boost::format("Irregular edge: (%1%,%2%)"
				     ", %3% facets.\n")
	    % e[ih].first % e[ih].second
	    % edge_it->second.size();
      } // end "for each neighbor of f"
    } // end "stack non empty"
  } // end "oriented_set not full"
    const int i = boost::get<0>(facets[i_facet]);
    const int j = boost::get<1>(facets[i_facet]);
    const int k = boost::get<2>(facets[i_facet]);
    if(oriented_set[i_facet])
      cout << "3 " << j << " " << i << " " << k << "\n";
    else
      cout << "3 " << i << " " << j << " " << k << "\n";
