- To:
- Subject: Circular Kernel Intersection troubles
- Date: Mon, 8 Oct 2007 11:39:13 +0200
I am new to the CGAL environment, and had the luck to start right away with
the rather new Circular_Kernel, as I need Intersections of Arcs;
To come to the problem: the intersection of arcs has as results points with
coordinates of the Root_of_2 type; how is it now possible to lay a simple
line_2 through two of such points, respectively how can I convert Root_of_2
to any type which can be used in the linear kernel, without loss of accuracy;
when I came to the conclusion that the conversion to double is the only
possible way (d'oh), i was confronted by another, even more crucial problem:
Is it in any way possible, to get the intersection point(s) of a line_2 with
a circluar_arc_2 yet? It is possible to cut a line_arc with a circular_arc,
so why not a line?
Waiting desperately for an answer,
mfg, Wolfgang
- Circular Kernel Intersection troubles, waigner, 10/08/2007
- Re: [cgal-discuss] Circular Kernel Intersection troubles, Monique . Teillaud, 10/08/2007
- Re: [cgal-discuss] Circular Kernel Intersection troubles, Wolfgang Aigner, 10/08/2007
- Re: [cgal-discuss] Circular Kernel Intersection troubles, Monique . Teillaud, 10/09/2007
