- To:
- Subject: Re: [cgal-discuss] Unique container of Facet_handles
- Date: Wed, 10 Oct 2007 16:52:09 +0200
Hi Bernhard
Define
operator<(const PFacet_handle& f1, const PFacet_handle& f2)
return &*f1 < &*f2;
This should work as std::set has less<T> as default comparator
which just calls operator<
andreas
Bernhard Kornberger wrote:
Dear list!
Having a Polyhedron_3 and a vector of critical vertices of it I need
to create a unique container of all Facets containing at least one of
the critical vertices. Something like:
set<PFacet_handle> sCriticalFacets;
for(unsigned i=0;i<criticalIndices.size();++i)
Halfedge_around_vertex_circulator circ1,circ2;
circ1=circ2=vHandles[criticalIndices[i]]->vertex_begin();
do
sCriticalFacets.insert(circ1->facet());
} while((++circ1)!=circ2);
Clearly it does not work because operator< is not defined for
the facet handle. Another idea is storing the facet_handles into
a STL vector and calling sort and unique using a functor:
class func_FacetSort
public:
bool operator()(const PFacet_handle fh1,const PFacet_handle fh2) const
// return ???
func_FacetSort fSort;
sort(vCriticalFacets.begin(),vCriticalFacets.end(),fSort);
unique(..);
..but what should this functor return? The only thing I can imagine is
to represent the vertices of the facets as strings and to compare them.
But this seems dirty and moreover this part is time critical. Any ideas
how to generate a container of facet_handles without duplicates?
Thx!
Bernhard
- Unique container of Facet_handles, Bernhard Kornberger, 10/10/2007
- Re: [cgal-discuss] Unique container of Facet_handles, Andreas Fabri, 10/10/2007
- Re: [cgal-discuss] Unique container of Facet_handles, Bernhard Kornberger, 10/10/2007
