cgal-discuss - Re: [cgal-discuss] Using "dD Convex Hulls and Delaunay Triangulations" package
  • To:
  • Subject: Re: [cgal-discuss] Using "dD Convex Hulls and Delaunay Triangulations" package
  • Date: Thu, 11 Oct 2007 18:46:34 +0200
Nora Ayanian wrote:
I would like to use the dD Convex Hulls and Delaunay Triangulations package to compute triangulations (intersections, etc.) of 6+ dimensional polytopes,
Dear Nora,
What kind of operations do you need on these polytopes? In case you need to use the Convex_hull_d package, I attach a previous message sent on this list which briefly presents how to use it.
starting from H-representation.
If you want to compute the V-representation from the H-representation, you will have to do the conversion "manually". In order to compute the V-representation of the intersection C of some halfspaces, you could:
1) first compute the d-convex hull of the (polar) dual points representing the hyperplanes (you will need to know at least one point inside C that will be used as a center for the polar duality)
2) then deducing the vertices of the convex hull C from the faces of D: if (h_0...h_5) is a (simplicial) face of D, then h_0\cap...\cap h_5 is a vertex of C.
3) if two faces of D share an edge, the corresponding vertices of C are adjacent.
Hope this helps,
Camille Wormser
--- Begin Message ---
  • To:
  • Subject: Re: [cgal-discuss] 6 Dimensional Space
  • Date: Fri, 27 Oct 2006 12:16:44 +0200
  • List-archive: <https://lists-sop.inria.fr/wws/arc/cgal-discuss>
  • List-id: <cgal-discuss.lists-sop.inria.fr>
wrote:
Can anyone please provide me with a simple example to calculate the convex
hull of a set of points in 6D, USING CGAL ?
Something like this should work :
#include <list>
#include <Convex_hull_d.h>
#include <CGAL/Cartesian_d.h>
typedef CGAL::Cartesian_d<double> Kd;
typedef CGAL::Convex_hull_d<Kd> CHull_d;
typedef CHull_d::Point_d Point_d;
typedef std::list<Point_d> List_ptd;
CHull_d* init_insertion(List_ptd points) {
CHull_d::Vertex_handle vh6;
List_ptd::iterator a, b;
a = points->begin();
b = points->end();
ch6 = new CHull_d(6);
while(a != b) {
vh6 = ch6->insert(*a);
++a;
A Point_d can be created by calling for example
Point_d(6, c.begin(), c.end());
where c is a list of 6 doubles.
Then, if you want to retrieve the points on the convex hull, you have access to iterators
ch6->Hull_point_const_iterator hull_points_begin()
ch6->Hull_point_const_iterator hull_points_end()
You also have the facets iterators
ch6->Facet_iterator facets_begin()
ch6->Facet_iterator facets_end()
and ch6->vertex_of_facet(facet,j) for j = 0..5 gives you the vertices.
ch6->vertex_of_facet(facet,j)->point() gives you the point.
ch6->vertex_of_facet(facet,j)->point().cartesian_begin() gives you an iterator on the coordinates.
You may however soon encounter robustness issues, and then need an exact number type (note that this Convex_hull_d computes and stores some hyperplanes, and is not completely predicate-based...).
Camille
--- End Message ---
