- To:
- Subject: Circular Kernel: clean way to convert from Circular_arc_point_2 to Point_2
- Date: Fri, 12 Oct 2007 09:45:35 +0200
My problem is the following: I have three points on arcs (therefor circular
arc points), and from these three points I want to construct a circle;
A circle can only be constructed from normal points, so i need to convert the
CAP to points, without loosing the has_on property of these points concerning
their origin arcs;
I see that the conversion from Root_of_2 isn't trivial, and not implemented
yet, anyhow: does someone have an idea how to implement this in a clean /
exact way, if the Root_of_2 number is of rational form?
mfg, Waigner
- Circular Kernel: clean way to convert from Circular_arc_point_2 to Point_2, waigner, 10/12/2007
- Re: [cgal-discuss] Circular Kernel: clean way to convert from Circular_arc_point_2 to Point_2, Monique . Teillaud, 10/12/2007
