- To: <>
- Subject: RE: [cgal-discuss] CGAL auto-link and gmp vs MS Visual C++
- Date: Fri, 12 Oct 2007 17:15:04 -0400
Thank you for clearing that up. This restriction was not clear to me,
because when I read in INSTALL.win32.txt:
"Note that you can alternatively install CGAL with the Microsoft
compilers using
Cygwin. For installation on Unix systems and on Cygwin, please see the
INSTALL
document."
I did not realize that an installation done using Cygwin would be
limited to using the Microsoft compilers from the command line.
What do you recommend for a user who needs to do development in the
Visual IDE, and also create release builds from the command line? I have
been working through the issues myself, but now that I know this
(installing from the command line and then building from the IDE) is a
non-recommended use, I would like to hear your suggestions before going
on at length about mine.
Thank you,
--Ed
-----Original Message-----
[mailto:]
Sent: Friday, October 12, 2007 5:03 PM
To:
Subject: Re: [cgal-discuss] CGAL auto-link and gmp vs MS Visual C++
On Friday 12 October 2007 20:47:29 Segall, Edward wrote:
> When I install CGAL 3.3.1 on a Windows machine under Cygwin using
> install_cgal (rather than using the precompiled installer) and I
> select the Visual C++ 8.0 compiler, it builds just one version of the
> CGAL library. This version is named CGAL.lib. When I then try to build
> an application using this installation, the auto-link mechanism causes
> a link failure because there is no library CGAL-vc80-mt.lib.
If you used install_cgal and Cygwin to compile CGAL, then you should use
nmake and makefiles to compile your applications. It seems that you
tried to compile a vcproj with Visual, using that CGAL installation.
> [...] Can you advise?
You should tell use why you are using install_cgal, instead of the
precompiled CGAL shipped with the Windows installer. For unknown
reasons, you have decided to use CGAL under Windows in a non recommanded
way.
Best regards,
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
Confidentiality Notice
This e-mail (including any attachments) is intended only for the recipients
named above. It may contain confidential or privileged information and should
not be read, copied or otherwise used by any other person. If you are not a
named recipient, please notify the sender of that fact and delete the e-mail
from your system.
- CGAL auto-link and gmp vs MS Visual C++, Segall, Edward, 10/12/2007
- Re: [cgal-discuss] CGAL auto-link and gmp vs MS Visual C++, Laurent Rineau, 10/12/2007
- RE: [cgal-discuss] CGAL auto-link and gmp vs MS Visual C++, Segall, Edward, 10/12/2007
- Re: [cgal-discuss] CGAL auto-link and gmp vs MS Visual C++, Fernando Cacciola, 10/12/2007
- RE: [cgal-discuss] CGAL auto-link and gmp vs MS Visual C++, Segall, Edward, 10/13/2007
