- To:
- Subject: Re: [cgal-discuss] Bbox_3 and Segment_3 intersection
- Date: Wed, 24 Oct 2007 17:51:57 +0800
Thanks Andreas! It worked great after using Iso_cuboid_3. I guess I was mistaken earlier since I saw an intersection(Segment_3, Bbox_3) function in intersection_3_1_impl.h.
Thanks again,
~ash
Andreas Fabri wrote:
Hi Ash,
The intersection only works between kernel objects and the Bbox_2
and Bbox_3 are not part of it, as they are hardwired with double
coordinates. For the intersection you must use the Iso_rectangle_2
or the Iso_cuboid_3 instead.
andreas
- Bbox_3 and Segment_3 intersection, Ashwin Nanjappa, 10/24/2007
- Re: [cgal-discuss] Bbox_3 and Segment_3 intersection, Andreas Fabri, 10/24/2007
- Re: [cgal-discuss] Bbox_3 and Segment_3 intersection, Ashwin Nanjappa, 10/24/2007
