- To:
- Subject: Re: Re: [cgal-discuss] question about minkowski sum
- Date: Thu, 25 Oct 2007 17:15:22 +0200
>It seems that you need to read the following introduction about offsets:
>http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Minkowski_sum_2/Chapter_ma>in.html#Section_15.3
>An offset of a polygon has circular arcs.
>See the example in the documentation cited above. Click on the names of the
>data structures. You'll see the documentation.
Thanks, I will read it
- Re: Re: [cgal-discuss] question about minkowski sum, nt_mahmood, 10/25/2007
