- To:
- Subject: Re: [cgal-discuss] what is polygon syntax
- Date: Thu, 25 Oct 2007 18:16:35 +0200
- Organization: Inria, Sophia Antipolis, FRANCE
On Thursday 25 October 2007 17:17:35
wrote:
> Hi,
> what is the syntax of a polygon? How can I create one? for example what
> does this mean?
> 64
> 100/1 -10/1
> 100/1 500/1
> 500/1 498/1
> 110/1 495/1
> 110/1 450/1
> 500/1 448/1
> 110/1 445/1
> 110/1 400/1
> 500/1 398/1
> 110/1 395/1
> 110/1 350/1
It seems that you use the homogeneous kernel, and all your points have hw=1.
The first line is the number of vertices. The next lines are each for one
vertices, with that format: "x y".
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
- what is polygon syntax, nt_mahmood, 10/25/2007
- Re: [cgal-discuss] what is polygon syntax, Laurent Rineau, 10/25/2007
