cgal-discuss - Comparing an iterator to a NULL value
  • To: "new_discuss" <>
  • Subject: Comparing an iterator to a NULL value
  • Date: Tue, 30 Oct 2007 21:54:10 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:date:to:subject:message-id:x-mailer:mime-version:content-type:from; b=TD0nJpqZt9Knw0pfi3E17KOVrmhJmQ0vmiJzEApQqnkH+t0B7bQxLC3t1Azonxq9UqOK20Yfcz7DK3FFmljKs/U+OzFfZGPuRmXQDpVyEN60WAS+NjbTDoKJQiy+6nTvR0WhihKmKgURli9SWG2pEbyiIX5aggOCX+FWE5rOAmw=
Hello, everyone:
I have a problem with iterators in a fairly complex polygonal mesh data
structure which is implemented using lists of geometric entities.
However, the problem in itself is fairly simple:
I need to define special iterator values. In particular, I want a null
iterator. This is different from end() which means the end of this
list. I want an iterator value that is known to just not correspond to
any element. It must be possible to compare using == and != and, of
course, this special value must be invariant to changes to the data
structure.
Say the type is
list<int>
and my special iterator is NULL_INT_LIST_ITERATOR
I want to compare like this
a == NULL_INT_LIST_ITERATOR
and this comparison should return true only if a has previously been
assigned my null value. Previously, I did this using
typedef list<int>::iterator IntIter;
IntIter NULL_INT_LIST_ITER(0);
This just defines an iterator with an internal null pointer. That works
fine in g++ but it is not documented that it should work. Arguably it
is ugly. A different solution is this
inline IntIter get_null_int_iter()
static list<int> l;
return l.end();
#define NULL_INT_LIST_ITER get_null_int_iter()
However, this solution does not work in recent version of Microsoft
visual studio. The reason *appears* to be that when I compare this
iterator value to a different iterator value it is detected that
NULL_INT_LIST_ITER belongs to a different list.
It seems you can make it work by defining HAS_ITERATOR_DEBUGGING=0.
However, the program still does not work - but possibly for different
reasons.
If you have a better solution, I'd be grateful to hear about it.
Thanks
Leon Nan
2007-10-30
