cgal-discuss - kdtree for product of 2 spaces
  • To:
  • Subject: kdtree for product of 2 spaces
  • Date: Fri, 2 Nov 2007 19:05:37 +0100
Hello,
I would like to build a kdtree for points that belong to the
cartesian product R^3 x S^2
to store and retrieve points with normals efficiently.
If a point is represented as u=(p,n) with p its 3d location and n the unit
normal on S^2 my distance is the following:
d(u1,u2) = max( ||p1-p2||/r, acos( n1.n2 )/(pi/2) )
where r is a constant.
In the example about kdtree
35.3.5 Example Illustrating Use of User Defined Point and Distance Class
it seems required that a distance to an iso-rectangle be defined.
So, in my case it seems that I should have my own implementation of an
iso-rectangle, the analogue of a Kd_tree_rectangle,
right ?
Is-it easy to make my own implementation of such a thing for the cgal kdtree
implementation, by any chance ?
- Best regards,
Manuel Yguel
  • kdtree for product of 2 spaces, manuel . yguel, 11/02/2007
