cgal-discuss - Re: [cgal-discuss] how to validate polyhedron vertex/halfedge/facet handles
  • To:
  • Subject: Re: [cgal-discuss] how to validate polyhedron vertex/halfedge/facet handles
  • Date: Tue, 06 Nov 2007 14:53:49 +0100
  • Organization: INRIA
Matthijs Sypkens Smit a écrit :
Dear all,
The CGAL triangulations allow you to check whether a cell or vertex is
part of the triangulation. I could not find similar functionality for
the CGAL polyhedron (polyhedral surface). When I store a bunch of
vertex, halfedge or facet handles, how do I check whether the handle
is still valid before trying to investigate the data structure at that
element?
Iterate over all elements of the polyhedron until you find it?
I was hoping for a somewhat more efficient method. I presume by your answer that none exists.
Currently nothing better than that. The triangulation only provide the
functions by convenience, more than by better algorithms.
It should be possible for triangulations to get an answer in O(sqrt(n))
instead of O(n) though, by exploiting the underneath memory layout
(see Compact_container). This is for Triangulation, not Polyhedron.
Of course, if you have a fast point location available with your
polyhedron, then you can build on it.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
