- To:
- Subject: Re: [cgal-discuss] Delaunay triangulation problem
- Date: Mon, 12 Nov 2007 13:12:53 +0900
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=tbZ3k1DOJhk3K5xfPm3nHc1dJqUjO9kFkEzeB/9W38muKjgIhZ52eEmLAML7h6cJeVg8LUp3A2EDsCYx4aXPGInLdYAJSqvOISP9pMf6O1bTQYy/SW0sIBrIStpG23EUjaNb+KLBBtYDOZBOCt08a/ObA7+UbfPwwJfg+va9F5c=
The problem is solved after gcc 4.2.1 is installed via Fink.
Thank you again.
On 11/12/07, Seungtaik Oh
wrote:
> Thanks Sylvain.
> I've just checked that a simple point insertion into a delaunay
> triangulation has the same problem. My gcc version is 4.0.1. I am
> trying to install 4.2.
> Seungtaik
> On 11/9/07, Sylvain Pion
> wrote:
> > Seungtaik Oh a écrit :
> > > Hi, all
> > > I am working on something that highly depends on Delaunay
> > > triangulation. However, there comes a bus error when I try to insert
> > > points by the method insert( first iterator, end iterator ). A strange
> > > thing is that the error is only for the case of optimization. No bus
> > > errors without optimization. I am writing the codes on MacOS 10.4.10
> > > and CGAL-3-3-1. What's wrong?
> > > My code looks like this :
> > > std::vector<Point> samplePoint;
> > > readSamplingPoints( samplePoint );
> > > // triangulate( 3d Delaunay triangulation)
> > > CGAL::Delaunay_triangulation_3<K> T;
> > > T.insert( samplingPoint.begin(), samplingPoint.end() ) );
> > Hard to tell without saying either a backtrace or the code of
> > readSamplingPoints.
> > That said, I know that g++-4.0 on Mac has some bugs when optimizing.
> > One option for you is to try g++-4.2 which is available in Fink.
> > Sylvain Pion
> > INRIA Sophia-Antipolis
> > Geometrica Project-Team
> > CGAL, http://cgal.org/
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Delaunay triangulation problem, Seungtaik Oh, 11/09/2007
- Re: [cgal-discuss] Delaunay triangulation problem, Sylvain Pion, 11/09/2007
- Re: [cgal-discuss] Delaunay triangulation problem, Seungtaik Oh, 11/12/2007
