Re: [cgal-discuss] BUG: incompatability between CGAL 3.3 and Rational ClearCase
- To:
- Subject: Re: [cgal-discuss] BUG: incompatability between CGAL 3.3 and Rational ClearCase
- Date: Fri, 16 Nov 2007 23:05:56 +0100
Pavlin, Andrew a écrit :
Greetings.
We had an unfortunate install problem with CGAL 3.3 when storing the CGAL source files in a ClearCase VOB. Because we weren't modifying any of the CGAL source files, we left them all not checked out (and therefore with read-only permissions), and attempted to run the install_cgal script to customize it to our development platform (we currently use three platforms: Microsoft Windows XP with Cygwin and g++ 3.3.3, Sun Solaris 10 with Sun Studio 11, and Red Hat Enterprise Linux with gcc 3.4, with ClearCase installed on all the development platforms). The install script started reporting errors about the time it got down to testing BOOST, wth repeated errors:
./install_cgal:2955: Permission denied
When the script completed, it claimed that BOOST could not be found, despite the fact that I had passed it in on the command line, and (in interactive mode) had specified it again before running the Test and Setup phase.
The problem turned out to be that all of the configuration testing source files in CGAL/config/testfiles had permissions 444 (read-only) because of being ClearCase controlled files. So the first test file was successfully copied to tmp_file.cpp, and all the remaining ones failed because the cp command couldn't overwrite the existing file (which preserved the permissions of the first copied file, rather than being owner-write access).
I managed to get the install_cgal script to work in this environment by checking it out, and inserting the line
${_chmod} u+w ${TMP_FILE_CXX}.cpp
after every occurrence of a ${_cp} sometestfile.cpp ${TMP_FILE_CXX}.cpp.
Another option would be to avoid the copy, and compile the original file directly. I haven't looked at the code so maybe there are reasons why
it would be not easy.
But, it any case, we are in the process of replacing the install_cgal
script by CMake, so I think it's not worth working on this dead end now.
Note that this file still has the problem with ignoring --BOOST_INCL_DIR; I have not tried to fix that problem, since I am told it is already a known bug.
Maybe the switch to CMake will fix this as well...
(and we'll have new fresh bugs to fix :-)
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- BUG: incompatability between CGAL 3.3 and Rational ClearCase, Pavlin, Andrew, 11/16/2007
- Re: [cgal-discuss] BUG: incompatability between CGAL 3.3 and Rational ClearCase, Sylvain Pion, 11/16/2007
