cgal-discuss - Re: [cgal-discuss] Delaunay_triangulation_3 benchmarking
  • To:
  • Subject: Re: [cgal-discuss] Delaunay_triangulation_3 benchmarking
  • Date: Thu, 22 Nov 2007 09:45:57 MET
Hello,
You may want to check a triangulation with hierarchy:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_hierarchy_3.html#Index_anchor_1260
I am not sure if it will make a huge difference for the creation of the
triangulation, but it should be interesting to try.
> At first I was naively using dt.insert(Point) [1] ...
> Later when I used dt.insert(InputIterator first, InputIterator last) I saw
> that it speeded up by more than 3 times.
Yes, that does make a great difference.
Best,
Daniel Duque
Mensaje enviado mediante una herramienta Webmail integrada en *El Rincon*:
------------->>>>>>>> https://rincon.uam.es <<<<<<<<--------------
