- To:
- Subject: Re: [cgal-discuss] Kd_tree interface
- Date: Fri, 23 Nov 2007 10:54:53 +0800
Matthijs Sypkens Smit wrote:
Hi,
In the manual for CGAL 3.3 it says that there is a class method clear(), to clear a Kd_tree, but it seems that is does not exist in the code. Looking at the code I conclude that at insertion the tree is cleared automatically. However, this is even the case for the insertion of a single point. Is there any use for a tree with just a single point?
Yes, Kd_tree.clear() is in the manual, but doesn't seem to be implemented. I see this problem too.
If I'm not wrong, it might be as simple as adding the following lines to kd_tree.h:
class Kd_tree {
public:
void
clear() const
pts.clear();
return;
~ash
- Kd_tree interface, Matthijs Sypkens Smit, 11/22/2007
- Re: [cgal-discuss] Kd_tree interface, Ashwin Nanjappa, 11/23/2007
- Re: [cgal-discuss] Kd_tree interface, Johannes Otepka, 11/29/2007
