- To:
- Subject: Re: [cgal-discuss] bug in CGAL 3.3.1 with GCC 4.1 and QT 3
- Date: Fri, 23 Nov 2007 17:33:55 +0100
Hi,
>> The GLU header files are missing:
>> /usr/lib/qt-3.3/include/qgl.h:80:21: error: GL/glu.h: No such file or
>> directory
> Thanks for info. the problem solved
> I wonder when there is no such file, why the test phase marked as OK?
The OpenGL test did not succeed in the test phase. In this case, some
parts of libCGALQt should be skipped during compilation. That is a bug
in our build system.
Joachim
- Re: Re: [cgal-discuss] bug in CGAL 3.3.1 with GCC 4.1 and QT 3, nt_mahmood, 11/23/2007
- Re: [cgal-discuss] bug in CGAL 3.3.1 with GCC 4.1 and QT 3, Joachim Reichel, 11/23/2007
