cgal-discuss - Re: [cgal-discuss] CGAL and Ubuntu
  • To:
  • Subject: Re: [cgal-discuss] CGAL and Ubuntu
  • Date: Sun, 2 Dec 2007 16:57:14 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=received:message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references:x-google-sender-auth; b=nn9RjM93eII1hNk+hD20L29MioHx2noDimZ7scfqoQ6puxSCEalBi8F483+/GVK/6iF4ip7g3pCoeRYY/ORPVs7plBvLrfEOIerA0cxA0HQfLEztAdkbAUb50yAUxaua/S3Obsma3es60xtqEVKrPFfZyT5EzZUJBLGlaKLpR3Q=
On Dec 2, 2007 4:45 PM, Mahmood NT
wrote:
> I tried to install CGAL in ubuntu. Even 3.3.1 and 3.2 could not be
> installed because it can not find compiler!
> here is the install.log for 3.2:
Works perfectly fine on ubuntu 7.10 and 7.04 here, just using
"./install_cgal --prefix=/usr/local" from the unpacked CGAL dir. Are
you sure g++ is installed? What is the output of "g++ --version"?
regards,
Bart Janssens
