cgal-discuss - Re: [cgal-discuss] reducing compile time
  • To:
  • Subject: Re: [cgal-discuss] reducing compile time
  • Date: Mon, 10 Dec 2007 01:30:08 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=FnLzmNgbcRUxnQxYN5QNKRZonfuYlawiBKENpuGw3IHku7uYMpaihA7etHlC2Hki3lVj9CgdksFzMC8fUysi5dCVyGZk9T2ULJ23dXdt6yny3/Wp8kJfZx6/GxiLdwvKOelofBK00mB3UbZqC33V9EVjxNoKmvYDbhJ5sFU2/Uw=;
>As already pointed out, ccache works on translation units. If you have
>only one translation unit, and edit any file, the cached copy of the
>translation unit is outdated and has be to recompiled.
Sorry but can you explain more about "translation unit". For example I want
to run voronoi demo. Does it have "one traslation unit"? How did you
determine that?
Thanks,
Mahmood NT
----- Original Message ----
To:
Sent: Monday, December 10, 2007 12:14:56 PM
Hi,
>> These are for caching a whole translation unit and wont help for CGAL,
>> because here, most programs only have one translation unit (one C file,
>> which includes everything else).
> I can not understand why ccache does not work for CGAL I tested it with my
> project and although the statistics show that somethings are cached, but th
> next compilation took nearly thesame time as first time.
ccache works fine with CGAL, but often you won't notice any benefit (see
below).
> In my case, I only change one file. So logically by using ccache, other
> header files that have not been changed, should be read from cache (during
> compilation).
> Does this mean that there is a mechanism in CGAL that clear or change the
> timestamp of files every time??
> It is strange.
No.
> Also, why do not developers embed a caching tool during CGAL installation?
Because it is not the task of a software library to decide on the
caching tool that should be used in a particular build
environment/software project.
Regards,
Joachim
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
