- To:
- Subject: Re: [cgal-discuss] A simple question
- Date: Mon, 10 Dec 2007 14:59:24 +0100 (CET)
- Importance: Normal
> I know have the explanation... The parameter P of your function app2, is a
> copy: the edges/facets/vertices of the original polyhedron are copied.
> When
> app2 returns, the returned handle is a handle to a facet of a temporary
> object. After the return of app2, the copy is destroyed, and your
> variable
> fd is a handle to an already destroyed object.
Ok, it is a C++ mistake.
> I have attached your example, that I have constify to the most, maybe to
> much. :-)
Thank you.
- A simple question, gbatog, 12/10/2007
- Re: [cgal-discuss] A simple question, Laurent Rineau, 12/10/2007
- Re: [cgal-discuss] A simple question, gbatog, 12/10/2007
- Re: [cgal-discuss] A simple question, Daniel Duque Campayo, 12/10/2007
