- To:
- Subject: Re: [cgal-discuss] .nef3 file format
- Date: Sun, 16 Dec 2007 09:28:09 +0100
Hi Bart,
sorry, I still did not really give your threshold numbers a try. But I
can give you a general remark on which assertions you want to take out
and which you should better let in. Because of your handling of
geometry, some geometry assertions fail. That should be OK. So, you
should kick out assertions that compare planes, circles and points. Did
you kick out other assertions? If yes, we should look at these,
closely.
What is the of your conversion operations between K3-D mesh and Nef
polyhedra. Does it run?
Greetings, Peter
> p.s. Peter, have you had the chance yet to look at the assertions I've
> proposed to remove in my patch?
- .nef3 file format, cgal, 12/10/2007
- Re: [cgal-discuss] .nef3 file format, Peter Hachenberger, 12/10/2007
- Re: [cgal-discuss] .nef3 file format, Bart Janssens, 12/10/2007
- Re: [cgal-discuss] .nef3 file format, Peter Hachenberger, 12/16/2007
- Re: [cgal-discuss] .nef3 file format, Bart Janssens, 12/16/2007
