- To:
- Subject: Re: [cgal-discuss] exact constructions kernel + 2D mesher ?
- Date: Mon, 17 Dec 2007 19:18:25 +0100
Hi Maarten,
As a workaround you might try to add
#define CGAL_DONT_USE_LAZY_KERNEL 1
It should compile.
andreas
Maarten Moesen wrote:
Hello,
When trying a 2D mesher example of CGAL together with the exact
constructions kernel I noticed that it doesn't compile on my PC (CGAL
3.3.1 / linux32 / g++ 4.0) giving error messages summarized by:
test.cpp:52: instantiated from here
/usr/local/CGAL-3.3/include/CGAL/Lazy.h:368: error: no matching function
for call to ‘exact(CGAL::Null_tag&)’
/usr/local/CGAL-3.3/include/CGAL/Lazy.h:83: note: candidates are: const
double& CGAL::exact(const double&) ... and so on.
This is only when using Exact_predicates_exact_constructions_kernel. For
Exact_predicates_inexact_constructions_kernel and
Exact_predicates_exact_constructions_kernel_with_sqrt it compiles (and
works :)
Is this OK? I'd like to use the
Exact_predicates_exact_constructions_kernel because I'm planning to make
some constructions using NEF polyhedra earlier on in the process and
found out that exact_..._with_sqrt doesn't work together with these.
(Maybe a second mail)
Thanks,
Maarten Moesen
Here's the code:
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Constrained_Delaunay_triangulation_2.h>
#include <CGAL/Delaunay_mesher_2.h>
#include <CGAL/Delaunay_mesh_face_base_2.h>
#include <CGAL/Delaunay_mesh_size_criteria_2.h>
#include <iostream>
struct K : public CGAL::Exact_predicates_exact_constructions_kernel {};
typedef CGAL::Triangulation_vertex_base_2<K> Vb;
typedef CGAL::Delaunay_mesh_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb> Tds;
typedef CGAL::Constrained_Delaunay_triangulation_2<K, Tds> CDT;
typedef CGAL::Delaunay_mesh_size_criteria_2<CDT> Criteria;
typedef CGAL::Delaunay_mesher_2<CDT, Criteria> Mesher;
typedef CDT::Vertex_handle Vertex_handle;
typedef CDT::Point Point;
int main()
CDT cdt;
Vertex_handle va = cdt.insert(Point(-4,0));
Vertex_handle vb = cdt.insert(Point(0,-1));
Vertex_handle vc = cdt.insert(Point(4,0));
Vertex_handle vd = cdt.insert(Point(0,1));
cdt.insert(Point(2, 0.6));
cdt.insert_constraint(va, vb);
cdt.insert_constraint(vb, vc);
cdt.insert_constraint(vc, vd);
cdt.insert_constraint(vd, va);
std::cout << "Number of vertices: " << cdt.number_of_vertices() <<
std::endl;
std::cout << "Meshing the triangulation with default criterias..."
<< std::endl;
Mesher mesher(cdt);
mesher.refine_mesh();
std::endl;
std::cout << "Meshing with new criterias..." << std::endl;
// 0.125 is the default shape bound. It corresponds to abound 20.6
degree.
// 0.5 is the upper bound on the length of the longuest edge.
// See reference manual for Delaunay_mesh_size_traits_2<K>.
mesher.set_criteria(Criteria(0.125, 0.5));
std::endl;
- Computing a convex hull with points derived from Point_2, Ole Schulz-Trieglaff, 12/17/2007
- Re: [cgal-discuss] Computing a convex hull with points derived from Point_2, Michael Hoffmann, 12/17/2007
- Re: [cgal-discuss] Computing a convex hull with points derived from Point_2, Andreas Meyer, 12/17/2007
- exact constructions kernel + 2D mesher ?, Maarten Moesen, 12/17/2007
- Re: [cgal-discuss] exact constructions kernel + 2D mesher ?, Andreas Fabri, 12/17/2007
- Re: [cgal-discuss] exact constructions kernel + 2D mesher ?, Maarten Moesen, 12/17/2007
- Re: exact constructions kernel + NEF polyhedra?, Maarten Moesen, 12/17/2007
- Re: [cgal-discuss] exact constructions kernel + 2D mesher ?, Laurent Rineau, 12/17/2007
- Re: [cgal-discuss] exact constructions kernel + 2D mesher ?, Maarten Moesen, 12/18/2007
