- To: ,
- Subject: Re: [cgal-discuss] Mesh Simplification
- Date: Wed, 19 Dec 2007 10:26:22 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=OataIogZoGkmptafNNezE4Fgvw8ap1FiNqhzLyFhLXDQaiygrQPzzzYZEbXzlYKs5Lg4Aumlzd7RYgT4DP2isFWOKAc3y18FisWFHTWxviFvKOvgUgOtxYAbANUMMqo7AJFQQQe6QfMMWT7Gxym3Al+Xtel7b6QP9PAP/EZHNjw=
#include "../Enriched_polyhedron.h"
#include "HalfedgeGraph_Enriched_polyhedron.h"
#include <CGAL/Surface_mesh_simplification/edge_collapse.h>
#include <CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Count_ratio_stop_predicate.h>
#include <CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Midpoint_and_length.h>
#include "../../../MeshStudioDoc.h"
namespace SMS = CGAL::Surface_mesh_simplification;
// The following is a Visitor that keeps track of the simplification process.
// In this example the progress is printed real-time and a few statistics are
// recorded (and printed in the end).
template <class Polyhedron, class Kernel>
struct Visitor
typedef SMS::Edge_profile<Polyhedron> Profile;
typedef typename Kernel::Point_3 Point;
Visitor(CMeshStudioDoc *pDoc)
: collected(0)
, processed(0)
, collapsed(0)
, non_collapsable(0)
, cost_uncomputable(0)
, placement_uncomputable(0)
, m_pDoc(pDoc)
// Called on algorithm entry
void OnStarted( Polyhedron& ) {}
// Called on algorithm exit
void OnFinished ( Polyhedron& ) {}
// Called when the stop condition returned true
void OnStopConditionReached( Profile const& ) {}
// Called during the collecting phase for each edge collected.
void OnCollected( Profile const&, boost::optional<double> const& )
if (m_pDoc == NULL)
return;
++collected;
m_pDoc->StatusMessage("Simplification: edges collected: %d", collected);
// Called during the processing phase for each edge selected.
// If cost is absent the edge won't be collapsed.
void OnSelected(Profile const&
,boost::optional<double> cost
,std::size_t initial
,std::size_t current
if (m_pDoc == NULL)
return;
++ processed ;
if ( !cost )
++ cost_uncomputable ;
if ( current == initial )
std::cerr << "\n" << std::flush;
// std::cerr << "\r" << current << std::flush ;
m_pDoc->StatusMessage("Simplification: current edges: %d", current);
// Called during the processing phase for each edge being collapsed.
// If placement is absent the edge is left uncollapsed.
void OnCollapsing(Profile const&
,boost::optional<Point> placement
if (m_pDoc == NULL)
return;
if ( placement )
++ collapsed;
else ++ placement_uncomputable ;
// Called for each edge which failed the so called link-condition,
// that is, which cannot be collapsed because doing so would
// turn the surface into a non-manifold.
void OnNonCollapsable( Profile const& )
if (m_pDoc == NULL)
return;
++ non_collapsable;
std::size_t collected
, processed
, collapsed
, non_collapsable
, cost_uncomputable
, placement_uncomputable;
CMeshStudioDoc *m_pDoc;
class CSimplifier
typedef typename Kernel::FT FT;
private:
// data
Polyhedron *m_pMesh;
public:
// life cycle
CSimplifier(Polyhedron *pMesh)
m_pMesh = pMesh;
~CSimplifier() {}
void run(FT ratio_stop=0.1, CMeshStudioDoc *pDoc=NULL)
Visitor<Polyhedron, Kernel> vis(pDoc);
if (!m_pMesh->is_set_items_id()) {
m_pMesh->set_hds_items_id();
// The simplification stops when the number of undirected edges
// drops below 10% of the initial count
SMS::Count_ratio_stop_predicate<Polyhedron> stop(ratio_stop);
SMS::edge_collapse(*m_pMesh,
stop,
CGAL::get_cost(SMS::Edge_length_cost<Polyhedron>())
.get_placement(SMS::Midpoint_placement<Polyhedron>())
.visitor(&vis)
Hi, GuysI am making a small application to do mesh simplification using Edge_Collapse template in CGAL.Somehow, i need to access the vertex that is kept in the mesh after one edge is collapsed.Is there a neat way to get that "vertex_descriptor" information?I am thinking of adding a function OnCollapsed(vertex_descriptor & ) to the Visitor, can someone point to me the right way to do so?Thanks a lot!Have a nice day!
Xuetao Yin
(Shu-e-tao)
Yours Sincerely
Zhi-Quan Cheng
http://zhiquan.cheng.googlepages.com
MeshStudio07-11-20.rar
Description: Binary data
- Mesh Simplification, Yin Xuetao, 12/14/2007
- Re: [cgal-discuss] Mesh Simplification, ZhiQuan Cheng, 12/19/2007
