- To:
- Subject: Re: [cgal-discuss] Circle Line Intersection
- Date: Wed, 19 Dec 2007 09:39:58 +0100
well, I really answered too quickly... (I mixed up Circular_arc_2 and Circular_arc_point_2)
Again, the problem comes from the fact that we forgot the case Line_2/Circle_2 in functor Intersect_2 that gives the interface for users, so, waiting for the fix, let's try to find a reasonable workaround. I have a few proposals:
1- Is it possible for you to clip your Line_2 into a Segment_2, just for computing the intersection?
If you can do this, then the simplest workaround is probably to use
CircularKernel::Intersect_2 for a Line_arc_2 and a Circle_2,
because Line_arc_2 can be constructed from Segment_2.
2- The intersection between Line_2 and Circle_2 is in fact coded internally in
include/CGAL/Circular_kernel_2/internal_functions_on_line_2.h
So, if you want to hack a little bit, you can probably use it.
3- You can also probably first construct a Circular_arc_2 from the circle and two identical lines equal to your line, I guess it should work, then ask for the endpoints of the circular arc.
I hope one of these workarounds can help.
陳 柏宏 wrote:
hi,
thanks for replying. i am still not sure how to use it
to find the intersection of a circle and line though..
- Circle Line Intersection, 陳 柏宏, 12/19/2007
- Re: [cgal-discuss] Circle Line Intersection, Monique . Teillaud, 12/19/2007
- Re: [cgal-discuss] Circle Line Intersection, 陳 柏宏, 12/19/2007
