- To:
- Subject: Re: [cgal-discuss] drawLine() does not work
- Date: Sun, 30 Dec 2007 18:32:07 +0100
- Organization: Inria, Sophia Antipolis, FRANCE
On Sunday 30 December 2007 13:10:13 Mahmood NT wrote:
> I use a simple:
> widget->get_painter().drawLine (1,1,4,3);
> but there is no line in the window. What is the problem?
Maybe the points (1,1) and (4,3) are outside of the viewport. Check it with
widget->get_painter->viewport().
Why do you want to use widget->get_painter() directly? Maybe you should use
the native Qt drawing tools. If you want to use native drawings with
CGAL::Qt_widget IO operators, you may want to use the following functions:
int widget->x_pixel ( double x)
and int widget->y_pixel ( double y).
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
- Re: [cgal-discuss] drawLine() does not work, Laurent Rineau, 12/30/2007
- <Possible follow-up(s)>
- Re: [cgal-discuss] drawLine() does not work, Mahmood NT, 12/31/2007
- Re: [cgal-discuss] drawLine() does not work, Laurent Rineau, 12/31/2007
- where to downlaod Qt for visual studio, Lin, Jeen-Shang, 12/31/2007
- Qt for visual studio is not free., Laurent Rineau, 12/31/2007
- RE: [cgal-discuss] Qt for visual studio is not free. - Email found in subject, Lin, Jeen-Shang, 12/31/2007
- Re: [cgal-discuss] Qt for visual studio is not free. - Email found in subject, Laurent Rineau, 12/31/2007
- Re: [cgal-discuss] Qt for visual studio is not free. - Email found in subject, Hongbo Fu, 12/31/2007
