- To:
- Subject: Re: [cgal-discuss] Re: Installing/Configuring CGAL on Visual Studio 2008
- Date: Mon, 31 Dec 2007 20:18:41 -0600
Yes I did, they point to the CGALROOT environment variable. I am trying
to make the demos work but I get an error on build which says that
following...
Project : error PRJ0019: A tool returned an error code from "Performing
Pre-Build Event..."
and the BuildLog.htm says
Creating temporary file "c:\Program
Files\CGAL-3.3.1\demo\Stream_lines_2\Debug\BAT00000130361096.bat" with
contents
@echo off
C:\Qt/bin/moc.exe -o streamlines.moc streamlines.cpp
if errorlevel 1 goto VCReportError
goto VCEnd
:VCReportError
echo Project : error PRJ0019: A tool returned an error code from
"Performing Pre-Build Event..."
exit 1
:VCEnd
Creating command line """c:\Program
Files\CGAL-3.3.1\demo\Stream_lines_2\Debug\BAT00000130361096.bat"""
I have installed Qt through it's windows installer, and the $QTDIR is
set to C:\Qt (which is where is installed on my computer)
-Raza
On Tue, 1 Jan 2008 02:40:02 +0100,
said:
> Hi,
> Did you add it to your 'include' directories?
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Mohammad Raza
http://www.fastmail.fm - Access your email from home and the web
- Installing/Configuring CGAL on Visual Studio 2008, mohammadraza, 01/01/2008
- <Possible follow-up(s)>
- Re: Installing/Configuring CGAL on Visual Studio 2008, franklin_ruiz01, 01/01/2008
- Re: [cgal-discuss] Re: Installing/Configuring CGAL on Visual Studio 2008, Mohammad Raza, 01/01/2008
