- To:
- Subject: Re: [cgal-discuss] Compiling error with Intel compiler
- Date: Fri, 4 Jan 2008 09:15:37 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:references:x-google-sender-auth; b=XEGYDfRnDt0qYbOnSWZODGL1ykDpljNIWZ41+MkFJvuYSAcdrdq97Z4vI29gYS8fq7dB8IhQPxZ2dVMEwPkUK0K2Ju1eRHBPC0IQCwYaBscOLwXBL464BUUUFzM40ajS2MIImShi73u48XMyu5LtUzcj9DLXglfeV4aK2cFnnxs=
I don't know about the first error, but the second error talks about RTTI. The dynamic_cast requires from the compiler to support RTTI. For you it means that you probable need to enable this compiler feature (probably by using some flag).
On Jan 4, 2008 4:26 AM, Seungtaik Oh <> wrote:
Hi allI have a strange compiling error with Intel compiler 10.0.025 as follows:===========================1. C:\Program Files\CGAL-3.3\include\CGAL/double.h(245): error: the global scope has no "nextafter"
return ::nextafter(d1,d2);2. C:\Program Files\CGAL-3.3\include\CGAL/Object.h(91): error #259: run-time support for RTTI is disabled
const Wrapper<T> *wp = dynamic_cast<const Wrapper<T> *>(Ptr());
detected during instantiation of "bool CGAL::Object::assign(T &) const [with T=CGAL::Object::empty]" at line 109===========================I am trying to rebuild a pre-existing solution to make a new executable with Intel compiler.When compiling the codes with MS compiler or Gcc, there was no problem.Do I need to recompile the source codes of CGAL again?Thank you.Seungtaik
- Compiling error with Intel compiler, Seungtaik Oh, 01/04/2008
- Re: [cgal-discuss] Compiling error with Intel compiler, Ophir Setter, 01/04/2008
- Re: [cgal-discuss] Compiling error with Intel compiler, Sylvain Pion, 01/04/2008
