- To:
- Subject: Re: [cgal-discuss] Nef Polyhedra take 2 (boolean ops)
- Date: Tue, 8 Jan 2008 22:26:18 -0600
- Domainkey-signature: s=main; d=mail.utexas.edu; c=nofws; q=dns; h=Received:Received:Received:Mime-Version:In-Reply-To: References:Content-Type:Message-Id: Content-Transfer-Encoding:From:Subject:Date:To: X-Mailer; b=rWoqt+oMaGuD1KXdb17wzZlQTSqnpTBGuulxnk48N3fQzahmoRSPJ PzuIeSHfJ0r2Tyt6zIbHE+WcrYObugF4mjHb5OL6JELw6tvZic4fa Skw9qie83wZD1Qa1bap+qGyi2MTG88XAcbAonS5HtywrSE5dZ3cqk ipEsqozG+/s0=;
ET didn't mean anything to the compiler.
typedef CGAL::Lazy_kernel<CGAL::Simple_cartesian<ET> > Kernel;
Did you mean for some other number type there? Also, I now have Gmp and mpfr.
-- Gilbert
On Jan 8, 2008, at 5:20 AM, Peter Hachenberger wrote:
Hi Gilbert,
now here we seem to have a bug, but not a bad one. I looked at your
nef-files and the obvious reasons for the problem is, that the geometry
in this file uses floating-point coordinates. The nef file-format is
supposed to output the coordinates always as homogeneous integer
coordinates. My code should recognize the used kernel and convert the
coordinates for the output accordingly. This seems not to happen. When
Rob tested your files, he used the off files, which have no problem.
There may be two reasons for the problem:
1. CGAL::Exact_predicates_exact_constructions_kernel evaluates to
something unexpected and therefore the wrong specialization is used for
the coordinate output.
2. The kernel evaluates correctly, but somehow the compiler chooses the
wrong specialization.
Let's find out, whether it's the first option. Please use the program
below to convert any off-file to a nef-file and look up whether your
output still uses floating point arithmetic.
Peter
#include <CGAL/Lazy_kernel.h>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Gmpq.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Nef_polyhedron_3.h>
#include <CGAL/Nef_3/SNC_indexed_items.h>
#include <CGAL/IO/Nef_polyhedron_iostream_3.h>
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef CGAL::SNC_indexed_items Items;
typedef CGAL::Nef_polyhedron_3<Kernel, Items> Nef_polyhedron;
int main() {
Polyhedron P;
std::cin >> P;
if(!P.is_closed())
std::cerr << "input polyhedron is not closed. "
<< "Cannot convert to Nef Polyhedron." << std::endl;
return 1;
Nef_polyhedron N(P);
std::cout << N;
On Mon, 2008-01-07 at 17:18 -0600, Gilbert Bernstein wrote:
Hello again,--
I've been trying to get boolean operations up and working now, and
am running into a bit of trouble. I was able to get a union of two
offset cubes to compute just fine, but when I tried to union a shark
model with a reflected version of itself I got the following error dump:
CGAL error: assertion violation!
Expr: c.has_on(p1)&&c.has_on(p2)
File: /usr/local/CGAL-3.3.1/include/CGAL/Nef_S2/Sphere_segment.h
Line: 57
Explanation:
terminate called after throwing an instance of
'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Line: 57
Expr: 0
File: /usr/local/CGAL-3.3.1/include/CGAL/Nef_3/SNC_io_parser.h
Line: 1277
Explanation:SNC_io_parser::read: no SNC header.
Expr: 0
Line: 1277
Explanation: SNC_io_parser::read: no SNC header.
Abort trap
Following is a tarball of all relevant code and models. The program
off2nef (included) was used to convert the shark into a Nef
polyhedron. The reflection was performed before reading the shark
into CGAL. (ie. with off2nef) The program "test" was then run on the
two .nef files to produce the above error message.
If anyone has the time to peek at all this, or just has the time for
helpful suggestions, they would be much appreciated.
-- Gilbert
- Nef Polyhedra take 2 (boolean ops), Gilbert Bernstein, 01/08/2008
- Re: [cgal-discuss] Nef Polyhedra take 2 (boolean ops), Rob Pieké, 01/08/2008
- Re: [cgal-discuss] Nef Polyhedra take 2 (boolean ops), Peter Hachenberger, 01/08/2008
- Re: [cgal-discuss] Nef Polyhedra take 2 (boolean ops), Gilbert Bernstein, 01/09/2008
- Re: [cgal-discuss] Nef Polyhedra take 2 (boolean ops), Peter Hachenberger, 01/09/2008
