- To:
- Subject: Re: [cgal-discuss] Is this a bug of Segment Delaunay Graph?
- Date: Fri, 11 Jan 2008 17:39:19 +0100
- Organization: INRIA
On Thu, 10 Jan 2008 21:08:04 +0800
"pumking"
wrote:
> I use the Segment Delaunay Graph package to calculate offsets of
> polygons. One of the result of some input polygons is strange.
> So I want to know if something wrong.
The answer is yes. Obviously (if your drawing code is correct)
something is wrong. :-)
More importantly,
1. It is useless to send the same message 4 times in a row.
2. It is highly plausible that no one answered your question because
you did not give enough details. You should at least indicate the
CGAL kernel type that you are using, and attach the input file
containing your polygon, so that others, with the will to help, can
reproduce your error and track the bug(s).
Regards,
Sam
- Is this a bug of Segment Delaunay Graph?, Leon Nan, 01/10/2008
- <Possible follow-up(s)>
- Message not available
- Is this a bug of Segment Delaunay Graph?, pumking, 01/10/2008
- Re: [cgal-discuss] Is this a bug of Segment Delaunay Graph?, Samuel Hornus, 01/11/2008
