- To:
- Subject: Re: [cgal-discuss] overlapping in 3D triangulation
- Date: Tue, 15 Jan 2008 09:09:59 +0100
Hi
My advice will be to look at the manual. The output format is described.
Best regards,
Monique Teillaud
wrote:
Hi,
I'm a new user of CGAL and I just tried the 3D triangulation feature in the
package. However, I'm very confused with the result, which is copied as
follows:
3
5
0 10 0 1
0 0 0 1
2 5 6 1
5 7 0 1
1 -1 -4 1
9
1 0 3 4
2 1 3 4
3 1 2 0
0 2 3 5
5 2 3 4
0 5 3 4
1 5 0 4
1 2 5 4
1 2 0 5
5 1 6 2
0 4 7 2
8 3 0 1
4 5 8 2
1 5 7 3
4 0 6 3
5 0 7 8
4 6 1 8
3 6 7 2
Basically, this is a polyhedron with five vertices, (0,10,0), (0,0,0),
(2,5,6),
(5,7,0) and (1,-1,-4). The simplest triangulation will contain just two
tetrahedrons (excluding the cells that contain infinite vertices). However, I
find that the result contains overlapping cells, for example, cell [1 0 3 4]
overlaps with cell [2 1 3 4]. Is this common to the 3D triangulation feature
of CGAL? Or did I misinterpret the result?
I'm very thankful for your kind instructions.
Wei
- overlapping in 3D triangulation, wli, 01/15/2008
- Re: [cgal-discuss] overlapping in 3D triangulation, Monique . Teillaud, 01/15/2008
- Re: [cgal-discuss] overlapping in 3D triangulation, Camille Wormser, 01/15/2008
