- To: <>
- Subject: RE: [cgal-discuss] linking problem
- Date: Mon, 21 Jan 2008 11:39:05 +0200
Ok,
So this is what I did:
# target entries
all: Epitopia$(EXE_EXT)
Scan$(OBJ_EXT): Scan.cpp
$(CGAL_CXX) $(CXXFLAGS) $(OBJ_OPT) Scan.cpp
svm_classify$(OBJ_EXT):svm_classify.cpp
$(CGAL_CXX) $(CXXFLAGS) $(OBJ_OPT) svm_classify.cpp
Epitopia$(OBJ_EXT):Epitopia.cpp
$(CGAL_CXX) $(CXXFLAGS) $(OBJ_OPT) Epitopia.cpp
Epitopia$(EXE_EXT): Epitopia$(OBJ_EXT) Scan$(OBJ_EXT)
$(CGAL_CXX) $(LIBPATH) $(EXE_OPT)Epitopia Epitopia$(OBJ_EXT) Scan$(OBJ_EXT)
svm_classify$(OBJ_EXT) $(LDFLAGS)
But I get the following error:
*** target pattern contains no `%'. Stop.
Any idea?
-----Original Message-----
[mailto:]
Sent: Monday, January 21, 2008 9:23 AM
To:
Subject: Re: [cgal-discuss] linking problem
Hi,
> Scan$(OBJ_EXT)\
> svm_classify$(OBJ_EXT)\
you should omit the backslash in the last line and add one in the already
existing line (or put everything in one line).
Regards,
Joachim
- Re: Re: [cgal-discuss] linking problem, nimrod rubinstein, 01/21/2008
- Re: [cgal-discuss] linking problem, Joachim Reichel, 01/21/2008
- RE: [cgal-discuss] linking problem, Nimrod Rubinstein, 01/21/2008
