- To:
- Subject: Re: [cgal-discuss] Precondition and assert failures using CGAL 3.3.1
- Date: Tue, 22 Jan 2008 13:21:31 +0800
Tuukka Kataja wrote:
Hello,
I'm experiencing weird precondition and assert failures when using CGAL with the following system:
64-bit Ubuntu 6.10
gcc 4.1.2
CGAL 3.3.1
As a minimal example, consider the attached code (minkowski.cpp). It terminates with
CGAL error: precondition violation!
Expr: nodeP != NULL && nodeP->is_valid()
File: /usr/local/include/CGAL/Multiset.h
Line: 338
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_S_construct NULL not valid
I tried your program and see a similar error. I'm on 32-bit WinXP, VC++ 2008 EE and CGAL 3.3.1.
~ash
- Precondition and assert failures using CGAL 3.3.1, Tuukka Kataja, 01/16/2008
- Re: [cgal-discuss] Precondition and assert failures using CGAL 3.3.1, Ashwin Nanjappa, 01/22/2008
