cgal-discuss - Re: [cgal-discuss] Constrained Delaunay Triangulations of non-convex polygons and donut-polygons
  • To:
  • Subject: Re: [cgal-discuss] Constrained Delaunay Triangulations of non-convex polygons and donut-polygons
  • Date: Tue, 22 Jan 2008 09:43:30 +0100
No, CGAL triangulations always cover the convex hull of the vertices.
Stephen Wong wrote:
Hello,
I have looked at using CGAL for performing triangulation of certain polygons.  They are:
1.       Non-convex polygons where the convex hull(polygon) != polygon
2.       Polygons with an inner hole, i.e. donut polygons.
The edges of the polygons are constraints in a Constrained-triangulation.  Is there a convenient way to simply triangulate these kind of polygons, without manually having to remove facets inside the inner hole and/or facets outside the polygon but inside the convex hull?
Thank you again,
Stephen
Mariette Yvinec
Geometrica project team
INRIA  Sophia-Antipolis
