- To: <>
- Subject: RE: [cgal-discuss] Using CGAL with Visual C++ 6
- Date: Mon, 28 Jan 2008 14:12:32 +0800
Hi, thanks for all your help. I am using CGAL as an add-on to my current
Cppunit test program which runs in MFC. As of now, the only commercial
compiler that I have is Visual C++ 6. I'm not sure if I can run the MFC test
runner for Cppunit on VC++ 2008 Express though...
Regards,
Kenneth
-----Original Message-----
[mailto:]
Sent: Monday, January 28, 2008 1:55 PM
To:
Subject: Re: [cgal-discuss] Using CGAL with Visual C++ 6
Wesley Smith wrote:
> I was asking myself the same question. VS2008 is available for free.
> Why not use it?
True. I'm using VC++ 2008 Express Edition (which is free) with CGAL and
having no problems at all.
~ash
[This e-mail is confidential and may be privileged. If you are not the
intended recipient, please kindly notify us immediately and delete the message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
- RE: [cgal-discuss] Using CGAL with Visual C++ 6, Kenneth Tham, 01/28/2008
- Re: [cgal-discuss] Using CGAL with Visual C++ 6, Ashwin Nanjappa, 01/29/2008
- Message not available
- RE: [cgal-discuss] Using CGAL with Visual C++ 6, #LIKE GOBEAWAN#, 01/29/2008
