cgal-discuss - Re: Re: [cgal-discuss] [Nef_polyhedron_3] interior(), closure() and boundary()
  • To: "" <>
  • Subject: Re: Re: [cgal-discuss] [Nef_polyhedron_3] interior(), closure() and boundary()
  • Date: Mon, 4 Feb 2008 22:50:54 +0800
  • Disposition-notification-to: "Max" <>
  • Organization: LoadCom
Hi Peter,
Thank you for your quick help! It's really a good news for me that
I seemed not to be COMPLETELY wrong. :-)
From the changes you've made on the code, if I understand
correctly, the definition of them could be refined further
as follows:
For a given Nef_polyhedron_3 N,
with interior(N), one gets the volume(s) that N originally has, without
any boundary item
with boundary(N), one gets the complete boundary of N, no matter wheather
they are originally included in N, without any volume.
with enclosure(N), one gets the volume(s) that N originally has, with the
complete boundary of it
If they are incorrect, partially or completely, please let me know.
Thanks again for your help.
>Hi Max,
>> From the doc, I get the brief definitions of them:
>> interior():With interior() one deselects all boundary items.
>> closure():with closure() one selects all boundary items.
>> boundary():with boundary() one deselects all volumes.
>I found that in the documentation and have to admit that the description
>is too simple. I will change it. It should be:
>interior: deselect all boundary items
>boundary: select all boundary items, deselect all volumes
>closure(N) = complement(interior(complement(N)))
>This complies with the mathematical operations.
>So your testcode could be as follows:
> Nef_polyhedron N_1(Plane_3( 1, 0, 0,-1), Nef_polyhedron::INCLUDED);
> Nef_polyhedron N_2(Plane_3( 1, 0, 0,-1), Nef_polyhedron::EXCLUDED);
> Nef_polyhedron N_pl = N_1 - N_2; // a plane slice
> Nef_polyhedron N_empty(Nef_polyhedron::EMPTY);
> CGAL_assertion(N_1.interior() == N_2);
> CGAL_assertion(N_2.interior() == N_2);
> CGAL_assertion(N_pl.interior() == N_empty);
> CGAL_assertion(N_1.closure() == N_1);
> CGAL_assertion(N_2.closure() == N_1);
> CGAL_assertion(N_pl.closure() == N_pl);
> CGAL_assertion(N_1.boundary() == N_pl);
> CGAL_assertion(N_2.boundary() == N_pl);
> CGAL_assertion(N_pl.boundary() == N_pl);
>As you can see, there are a few lines, which remained unchanged. I
>tested the code and also had problems.
It's still not clear for me. You mean the 'problem' is just the
'correct' result or it will be solved/refined later?
>It works nicely for the standard
>kernels, but using an extended kernel, the special handling of the
>infimaximal box causes problems. I guess you need the topological
>operations combined with the extended kernel, don't you?
What I really need is just the capability of input of data
with double data type and perform some bool operation. Runnability
and performance is more important than exactness in my current
application.
>Peter
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
