- To:
- Subject: Re: [cgal-discuss] Segfault in CGAL
- Date: Tue, 5 Feb 2008 12:23:51 +0100
- Organization: Inria, Sophia Antipolis, FRANCE
On Tuesday 05 February 2008 11:30:49 Thomas Zangl wrote:
> Laurent Rineau schrieb:
> Hi!
> > The problems occurs in a filtered predicate, during the conversion from
> > your kernel to the filtering kernel. What compile flags do you use? Have
> > you disabled the CGAL assertion (with -DNDEBUG for example)?
> I installed CGAL using: ./install_cgal
I meanĀ : how do you compile your application? Do you use a makefile provided
by CGAL of cgal_create_makefile?
> Nothing more, nothing less :-) But I tried it now on my gentoo box.
> Information:
> gcc (GCC) 4.2.2 (Gentoo 4.2.2 p1.0)
> glibc-2.7-r1
Different compiler, actually. Ubuntu 7.10 uses g++-4.1.2, which is usually
more usable than 4.2.
> Compiled my application (same as on my Ubuntu box), ran it, works. Strange?
> It seems Ubuntu broke something during their last update cycle? I will
> dig into it today evening..
CGAL packages in Ubuntu are the ones from Debian, made by
Joachim Reichel
They have not been updated since the
release of Ubuntu 7.10. However, gmp packages have been update very recently
and that could be the reason.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
- Segfault in CGAL, Thomas Zangl, 02/04/2008
- Re: [cgal-discuss] Segfault in CGAL, Laurent Rineau, 02/05/2008
- Re: [cgal-discuss] Segfault in CGAL, Thomas Zangl, 02/05/2008
- Re: [cgal-discuss] Segfault in CGAL, Sylvain Pion, 02/05/2008
