cgal-discuss - Re: [cgal-discuss] CGAL and Boost Graph lib
  • To:
  • Subject: Re: [cgal-discuss] CGAL and Boost Graph lib
  • Date: Wed, 6 Feb 2008 14:17:28 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=lLvgBMgdIrp0jkOxrVh/5PNhvRsEqihXEcOf23WgsejEHr3OHBavrGNaB7DB967h0zRiblcwLUp6C8ojmbWdhmqPg01FuRl3GIrE705bRRdB2Txp3/qP//G8zHspucdWyxBttk1fs4p9DMfG96w+IjxJGvrJS7km39GPtz6VBhM=
ok thank
there's a way to know if my map is read-only or to converte them in writable??
I write only  the command "boost::property_map<Triangulation,boost:edge_weight_t>::type ...",  and I not define the map, I think that Cgal triangulation is my map (graph), or not??
Sorry but it's the first time that I use CGAL and boost.
Bye
2008/2/6, Laurent Rineau <>:
On Wednesday 06 February 2008 13:17:15 BomBielFil wrote:
> Why "get" do right and put no?Can help me??
Maybe your property map is read-only. Remember that the Boost Property Map
library defines four concepts:
  ReadablePropertyMap
  WritablePropertyMap
  ReadWritePropertyMap
  LvaluePropertyMap
(see http://www.boost.org/libs/property_map/property_map.html).
If your property map is not model of the WritablePropertyMap concept, you
cannot use put with it.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
