- To:
- Subject: Re: [cgal-discuss] CGAL::join Function
- Date: Tue, 12 Feb 2008 16:23:07 +0200
Kenneth Tham wrote:
Hi,First of all you should call the join function just once with a range of
I am using the CGAL::join function for joining polygon_with_holes_2
objects. In my program, I use the join function for about 10000 times
consequtively(trying to join a polygon to a set of polygons). My program
takes quite a long time to process this part ( several minutes ). Is it
normal for this function to take this amount of time? Thanks.
Regards,
Kenneth
input polygons (or polygons with holes). If you intend to perform other
operations in a sequence, you should call the join member function of
Polygon_set_2 instead of the global join function. Finally, I assume you
are using a exact-prediacte exact-construction kernel (for a good
reason). This means that all operations are caried out in an exact
maner. You can try to expedite the computation by reducing the bit
length of the input coordinates.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- CGAL::join Function, Kenneth Tham, 02/12/2008
- Re: [cgal-discuss] CGAL::join Function, Efi Fogel, 02/12/2008
