- To:
- Subject: Re: [cgal-discuss] Cannot open include file: 'boost/config.hpp'
- Date: Fri, 22 Feb 2008 09:54:58 -0600
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:references:x-google-sender-auth; b=NWGDexqHi3AkMpIByCdOTz219e54v9FZjvYj7CFo8E+eiY2iwI325D6Hzz5GSlrzlsH3huZ6fGSjJMnhK0eD97HCMsTVlrS83W77+YAe8cCwQCKtJfgfwJqymjBi964hrD3Hf1n4k/Y7uKydtaYmxRCbmNhAfdIQ1g3GIv15Tjo=
I thought the windows installer will install "Boost" for me. Now it looks like the windows installer doesn't do this.
Thank you very much!
On Fri, Feb 22, 2008 at 9:50 AM, Christian Friedrich <> wrote:
Hi there,
you'll have to download the Boost Library
http://sourceforge.net/project/showfiles.php?group_id=7586
and unpack the "boost" folder into the "CGAL-3.3.1\include" folder of your CGAL installation, so it's CGAL-3.3.1\include\boost
Says so in INSTALL.win32.txt
Best,
Christian--
On Fri, Feb 22, 2008 at 4:29 PM, <> wrote:
Hello,
I am new to CGAL.
I downloaded the newest CGAL-3.3.1 windows installer, and installed it. My compiler is visual studio 2005. The operation system is Windows XP.
When I tried to compile some examples in the example folder, but the compiler output an error "Cannot open include file: 'boost/config.hpp'". I checked the 'include' folder, and can not find this file.
Can someone tell me what's wrong?
Thanks!
Best Regards,
Christian Friedrich MSc ing
Phd candidate
Technische Universiteit Delft
Hyperbody
www.hyperbody.bk.tudelft.nl
Berlageweg 1
2628 CR Delft
kab. 1.37
T: +31 (0)15 27 85954
M: +31 (0)6 16 43 1661
E:
Regards,
Xiaoming Luo
Industrial & Manufacturing Systems Engineering
Iowa State University
1210 Sweeney Hall
Ames, IA 50011, USA
001-515-441-0123
- Cannot open include file: 'boost/config.hpp', xluo, 02/22/2008
- Re: [cgal-discuss] Cannot open include file: 'boost/config.hpp', Christian Friedrich, 02/22/2008
- Re: [cgal-discuss] Cannot open include file: 'boost/config.hpp', Xiaoming Luo, 02/22/2008
- Re: [cgal-discuss] Cannot open include file: 'boost/config.hpp', Andreas Fabri, 02/22/2008
