- To:
- Subject: Re: [cgal-discuss] Problem with CGAL-3.3.1 and Gmp on Windows
- Date: Sun, 2 Mar 2008 18:43:48 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:references:x-google-sender-auth; b=S+n1udvttOwwmMWSFx2UfCMdU6VfJmqX++VtzTA8WV0IxKj87u+TD7I/8ibk8NVqMufutsERhRwKwslttjd9fXB7JZRAHtp10M0/xPt515x6dTepign75YVaOHYZ8Z9aP02kc+KOCv4bBfh6zqJ0rL8PkyoPyO6gMGDBvTPVkBw=
As I said, there is no problem with Release mode. The problem is only in Debug mode.
On Sun, Mar 2, 2008 at 6:39 PM, Xiaoming Luo <> wrote:
Hello,Try to use the "Release" mode to compile the project.
--On 3/2/08, Ophir Setter <> wrote:Hello,
One of our students had encountered a problem when installing CGAL-3.3.1 official version using the windows installer. There was no problem with the installer, but when he tried to build some of the examples (using VS2005 or VS2008) he got the following error:
"This application has failed to start because the application configuration is incoorect. Review the manifest for possible error.
Reinstalling the application may fix this problem. for more details, please see the application event log."
This error only happened in Debug mode and only when using Gmp. I guess that this thing has something to do with the (maybe missing) Gmp library files.
Any ideas?
Regards,
Ophir
Regards,
Xiaoming Luo
Industrial & Manufacturing Systems Engineering
Iowa State University
1210 Sweeney Hall
Ames, IA 50011, USA
001-515-441-0123
- Problem with CGAL-3.3.1 and Gmp on Windows, Ophir Setter, 03/02/2008
- Re: [cgal-discuss] Problem with CGAL-3.3.1 and Gmp on Windows, Xiaoming Luo, 03/02/2008
- Re: [cgal-discuss] Problem with CGAL-3.3.1 and Gmp on Windows, Ophir Setter, 03/02/2008
