- To:
- Subject: Re: [cgal-discuss] incident_edges?
- Date: Mon, 10 Mar 2008 15:27:06 +0000
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=SNvZwqk2xRClEdZjOrOX06naLngk80/PPOa+4gyaJvTLWi7mnARPgeYidvN3Cj0gigjzQkTqajII3zc0GK9nAl/CErJwPJMqQ7pyIFp7kw8wLBwAAtMTrC+c0bwhIJ+8KrekgHE5ra+5Pd/I01Y2lTdkQ6LJk64yYrJLanvOnhQ=
Soeey about not mentioning the original discussion, I thought it would have been attached automatically, my mistake. Anyway, thanks for your answer I'll try it now and maybe come back to you if I get problems.
Cheers
Angelo
On Mon, Mar 10, 2008 at 3:17 PM, Manuel Caroli <> wrote:
Dear Angelo,
first of all: it would have been nice to mention that the discussion
you're referring to dates back to October 2007 ;-)
For each cell incident to your vertex v, you visit all three incident
wrote:
> I'm dealing with the same problem but I didn't get the methond Andreas has proposed.
> What's the thing about checking in a set<Vertex_handle>?
edges. Thus you would output each edge several times (once from each
incident cell), which you probably don't want to do...
Assume we consider cell c.
> So far I've managed to retrieve the incident cells but I'm wondering how I can visit the edges.
> the vertex v is fixed but how can I determine the other vertices?
> I understood that I can get the edges providing the indices of the
vertices (0,1,2,3)
You get the index of v by v_ind = c->index(v).
So the three edges you get from c are the triples
(c, v_ind, ((v_ind+i)%4) )
with i\in {1,2,3}
In general: use the Cell_handle::index(int) method as shown above.
> how can I get these indices from a vertex handle?
The idea of the std::set<Vertex_handle> is to store the respective
vertex c->vertex((v_ind+i)%4) in the set and before returning an edge,
check whether the second vertex of that edge is contained in the set
(which means you have this edge already)
> Thanks for your help
Please ask again if I wasn't clear enough...
Best
Manuel
- Re: Re: [cgal-discuss] incident_edges?, angelo . tardugno, 03/10/2008
- Re: [cgal-discuss] incident_edges?, Manuel Caroli, 03/10/2008
- Re: [cgal-discuss] incident_edges?, Angelo Tardugno, 03/10/2008
