- To:
- Subject: alpha shape problem
- Date: Mon, 10 Mar 2008 14:45:52 -0400
Hello everyone,
I am having a problem running alpha-shapes_2 on larger points list (>100,000 points). Smaller lists work ok (after I added: #define _HAS_ITERATOR_DEBUGGING 0). However, with larger lists I now get the error:
DEBUG ASSERTION FAILED!
Expression: vector insert iterator outside range
Thanks for any advice.
Murray
- alpha shape problem, Murray Richardson, 03/10/2008
