- To:
- Subject: Re: [cgal-discuss] alpha_shape_2 rounding issue
- Date: Mon, 10 Mar 2008 13:36:36 -0700
Murray Richardson wrote:
Hello again,
This is probably a very simple question but I am new to CGAL and C++. When I create alpha shapes (Alpha_shape_2) on a set of points in real world UTM coordinates (e.g. sample: 463540.18 5263448.13) the output segments are rounded to the nearest metre (e.g. 463540) and 10 metres (5263450). Is there a simple way to stop this?
Thanks
Murray
Hi Murray,
It might help if you tell us what kernel you use and how your code for IO
looks like.
andreas
- alpha_shape_2 rounding issue, Murray Richardson, 03/10/2008
- Re: [cgal-discuss] alpha_shape_2 rounding issue, Andreas Fabri, 03/10/2008
- Re: [cgal-discuss] alpha_shape_2 rounding issue, Murray Richardson, 03/11/2008
- Re: [cgal-discuss] alpha_shape_2 rounding issue, Andreas Fabri, 03/11/2008
