cgal-discuss - Re: [cgal-discuss] Triangulation_2 question
  • To:
  • Subject: Re: [cgal-discuss] Triangulation_2 question
  • Date: Wed, 12 Mar 2008 08:26:01 -0400
I noticed several of the algorithms (such as Polygon/Polygon
intersection) require that each polygon have a counter-clockwise
orientation.
Polygon_2 poly(...);
if (poly.orientation() == CGAL::CLOCKWISE)
poly.reverse_orientation();
I hope this helps, I am also new to CGAL,
-- Eric
On Wed, Mar 12, 2008 at 01:39:49PM +0300, Boris Kazakov wrote:
> Hi, I'm new to CGAL and I'd like to do the following:
> Create a new Triangulation_2
> Add several points to it(for example, (0,0), (10,0), (10,10),
> (0,10),(5,5))
> Then move central point somewhere and check, weather the
> triangulation remains valid(by calling is_valid() method)
> When I am moving central point outside of the box [0,0,10,10] I get the
> following error:
> CGAL error: assertion violation!
> Expr: s == LEFT_TURN
> File: /usr/local/include/CGAL/Triangulation_2.h
> Line: 633
> Is there a way to disable this assertion violation, so that after
> moving the point is_valid method will return false?
> Thanks,
> Best regards.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
