- To:
- Subject: Re: [cgal-discuss] Problem with CGAL-3.3.1 and Gmp on Windows
- Date: Fri, 14 Mar 2008 16:21:12 +0000
Yes, the pre-compiled libraries are there.
However, I have the same problem as Ophir with compiling a project in Debug mode that uses CGAL and GMP. When I run it, I get the following error:
"This application has failed to start because the application configuration is incorrect. Review the manifest for possible error.
Reinstalling the application may fix this problem. for more details, please see the application event log."
However, it runs without error in Release mode.
I also get the following warnings when I compile in Debug mode:
1>Linking...
1>gmp-vc80-mt-gd.lib(aors.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(clear.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(cmp_si.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(cmp_ui.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(div.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(equal.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(init.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(mul.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(set_d.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(set_si.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(add.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(divegcd.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(divexact.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(gcd.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(realloc.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(set.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(set_ui.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(sub.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(tdiv_q.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(tdiv_q_2exp.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(tdiv_qr.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(submul_1.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(sub_n.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(sub_1.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(sub.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(sqr_basecase.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(sb_divrem_mn.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(rshift.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(mul_n.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(mul_fft.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(mul_basecase.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(mul_1.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(mul.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(mode1o.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(lshift.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(gcd_1.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(gcd.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(divrem_2.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(divrem_1.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(diveby3.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(dive_1.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(dc_divrem_n.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(cmp.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(bdivmod.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(addmul_1.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(add_n.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(add_1.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>gmp-vc80-mt-gd.lib(add.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>mpfr-vc80-mt-gd.lib(divrem.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\mpfr-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>mpfr-vc80-mt-gd.lib(random.obj) : warning LNK4099: PDB 'mpn-vc80-mt-gd.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\mpfr-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\mpn-vc80-mt-gd.pdb'; linking object as if no debug info
1>mpfr-vc80-mt-gd.lib(urandomb.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'C:\Program Files (x86)\CGAL-3.3.1\auxiliary\gmp\lib\mpfr-vc80-mt-gd.lib' or at 'c:\3D Modelling Framework\CGAL_meshing\CGAL_meshing\debug\vc80.pdb'; linking object as if no debug info
On 3/2/08, *Ophir Setter* < <https://lists-sop.inria.fr/wws/arc/cgal-discuss/2008-03/>> wrote:
As I said, there is no problem with Release mode. The problem is only in Debug mode.
On Sun, Mar 2, 2008 at 6:39 PM, Xiaoming Luo < <https://lists-sop.inria.fr/wws/arc/cgal-discuss/2008-03/>> wrote:
Hello,
Try to use the "Release" mode to compile the project.
Hello,
One of our students had encountered a problem when installing
CGAL-3.3.1 official version using the windows installer. There
was no problem with the installer, but when he tried to build
some of the examples (using VS2005 or VS2008) he got the
following error:
configuration is incoorect. Review the manifest for possible error.
This error only happened in Debug mode and only when using Gmp.
I guess that this thing has something to do with the (maybe
missing) Gmp library files.
Any ideas?
Regards,
Ophir
-- Regards,
Xiaoming Luo
Industrial & Manufacturing Systems Engineering
Iowa State University
1210 Sweeney Hall
Ames, IA 50011, USA
001-515-441-0123
Laurent Saboret wrote:
Hi,
GMP pre-compiled libraries are included in CGAL 3.3.1 installer. If you selected the proper option during the installation process, they are in P:\ath\to\CGAL-3.3.1\auxiliary\gmp.
The example VC++ projects included with CGAL should already have this folder in the include paths.
Regards,
- Re: Re: [cgal-discuss] Problem with CGAL-3.3.1 and Gmp on Windows, drk07, 03/14/2008
- Re: [cgal-discuss] Problem with CGAL-3.3.1 and Gmp on Windows, Laurent Saboret, 03/14/2008
- Re: [cgal-discuss] Problem with CGAL-3.3.1 and Gmp on Windows, Daniel Ryan King, 03/14/2008
- RE: [cgal-discuss] Problem with CGAL-3.3.1 and Gmp on Windows, Louis Feng, 03/14/2008
- Re: [cgal-discuss] Problem with CGAL-3.3.1 and Gmp on Windows, Fernando Cacciola, 03/14/2008
