Hi
Default name of compiled qt library is qt-mt3.lib.
Just rename qt-mt.lib to qt-mt3.lib in project setting.
regards
Sent: Tuesday, March 18, 2008 2:24 PM
To:
Subject: RE: [cgal-discuss] VC++ complie Error
Hi,
Yes, it totally works! Thank you. That's very nice of you, and I DO appreciate
your kind help.
Now, I am working with Visual Studion 2005, Qt3.3.8. I can run the source demo
programmes under "C:\Qt3.3.8\examples", and it run smoothly.
Unfortunately, when I tried to run the source code demo in CGAL 3.3.1,
(Segment_Delaunay_graph_2), I got one and only one error as belows:
"1 fatal error LNK1104: cannot open file
'qt-mt.lib' polygon_delaunay_graph_2"
I searched qt-mt.lib on my PC, but could not find it. Any ideas?
So sorry for inconvenience bring to you. Any advice is highly appreicated. Thank
you again.
Sincerely,
Xintao
To:
Date: Mon, 17 Mar 2008 17:08:13 +0900
Hi
1. rename unzipped directory to something like C:\Qt3.3.8
2. In My Computer->Advanced tab->Environmental Variable
Define QTDIR = C:\Qt3.3.8
Add $(QTDIR)\bin to Path
environmental variable
3. run C:\Program Files\Microsoft Visual Studio 8\VC\varsall.bat
4. cd C:\Qt3.3.8
Run configure-msvc2005.bat
5. It takes time to build.
That’s all
Regards
Sent: Monday, March 17, 2008 3:44 PM
To:
Hi,
Many thanks for your kind and prompt reply. I have downlaoded the Qt 3.3.8 and
unzip it. But in the folder there is no installation file just like Qt 4.3.4
does.
How to use it? I am somewhat puzzled. Could you please give me any
instruction?
Thanks and cheers.
Sincerely,
Xintao
> From:
> To:
> Date: Mon, 17 Mar 2008 13:19:33 +0900
> Hi
> CGAL3.3.1 does not support Qt 4.3.4.
> You have to use Qt version 3.
> Qt 3.3.8 for window can be downloaded at following link.
http://sourceforge.net/project/showfiles.php?group_id=49109&package_id=42335
> &release_id=507422
> regards
> -----Original Message-----
> From: [mailto:]
> Sent: Sunday, March 16, 2008 6:22 PM
> To:
> Subject: [cgal-discuss] VC++ complie Error
> Hi, all
> I want to compile and debug some of the demo program of CGAL! 3.3.1 after
> installation. Now I have installed Visual studio 2005, and my OS is
Windows
> XP Professional, also I in! stalled QT4.3.4 and Boost1.34.1. The errors I
met
> are as belows:
> 1. Error 4 error C2143: syntax error : missing ';' before '&'
c:\program
> files\cgal-3.3.1\include\cgal\io\qt_widget.h 74
> 2. Error 5 error C2433: 'CGAL::Qt_widget::QWMatrix' : 'inline' not
> permitted on data declarations c:\program files\cgal-
> 3. Error 6 error C4430: missing type specifier - int assumed. Note: C++
> does not support default-int c:\program files\cgal-
> Any ideas? Thanks and cheers.
> Sincerely,
> Xintao
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists! -sop.inria.fr/wws/info/cgal-discuss
> You a re currently subscribed to cgal-discuss.
> To unsubscrib! e or access the archives, go to
> https://lists-sop.inria.fr/wws /info/cgal-discuss
Windows
Live Writer,支持离线撰写博客内容,随时随地想写就写。 立即使用!
轻松把Hotmail下载到本地,试试 Windows Live Mail。 立即尝试!
